Comet Garrad C/2009 P1
Hi all,
Been quite a while since we last saw a nice comet. Here's one which may hold some promise and located in an area of the sky away from the sun's glare - Garrad C/2009 P1.
It is currently in the constellation of Pegasus at magnitude 8.2, with a 9' coma. It is expected to brighten by 0.7 magnitudes, and gradually moving towards Sagitta/Aquila region end of this month. At this magnitude, it is possible to already image it with our DSLRs in semi-dark skies.
Finder chart can be seen
here.
Have fun!
Photon Bucket
Yes, I have been following it with the RASO.
This was taken on 1 Aug, exposure 5 mins:
starfinder
Post by starfinder »
Thanks Remus for another lead!
I took some images of the comet this evening.
Here is one taken at 9:53pm (5 Aug 2011 1353UTC)
Position at: RA: 21h 20m 43s Dec: +13°45'33" (Equatorial 2000)
Imaging details: Meade LX-90 8"SCT f/10. Canon EOS60D, 20s, ISO 800.
Immediately below is the original image, full field of view.
Below that is a screen capture of The Sky6 software showing roughly the same field of view as the camera. From the pattern of the stars, we can see that the field of view matches.
So the identity of the object as Comet C/2009 P1 (Garradd) is I think confirmed. However, I hope to take another image soon to see if the comet's movement can be detected.
The reference star is SAO 107049 of mag 8.73.
According to the BAA's Comet Section, the comet's magnitude is now around 8.5:
http://www.ast.cam.ac.uk/~jds/
The third item below is the same image at 100% (cropped).
Visually, I thought I may have seen the comet through the eyepiece just now, but not certain. Will try again to confirm.
starfinder
I can now confirm that there is no doubt it is the comet, for the image below (20s at ISO1600) shows that it has moved quite a lot. In the words of Galileo, "Eppur si muove".
This was was taken at 11:07pm local time (1507UTC), i.e. 1 hr 14 mins after the first one.
Using the planetarium software, I estimate the movement to be about 2 arc minutes based on a comparison of the distances of the other stars with each other.
I also attempted another visual observation of it. I used a 14mm eyepiece, for about 143x power. I am confident that I did indeed manage to observe the comet from here in central Singapore. This was with direct vision. The object looked different from the surrounding pinpoint stars (around mag 9 to 10), as it was diffuse but with a brighter core. It is not bright or obvious, but once seen it is clearly there.
For the record, the comet was in the constellation Pegasus, near the border with Equuleus and Delphinus, and not too far from the globular cluster M15.
Now, let's hope it brightens, and not just moves.
wow you guys are fast! brilliant! still waiting for my camera.... today's weather looked good too.
Photon Bucket
starfinder
Ok, I've made a side-by-side montage of the same two frames.
As I was using a alt-azi mount, I had to rotate the 2nd image to the exact same orientation as the first one, and then cropped the two to have the exact same rectangular field of view.
Now the comet's movement in just over an hour can clearly be seen.
(Edit: I've boosted the brightness of the frame on the left (taken at ISO 800) to make the stars near the comet easier to see and also to be similar in brightness to the frame on the right (taken at ISO 1600))
Great stuff Gavin! It moved!
Great effort Gavin. Always amazed at your energy!
Its so convenient to have a good balcony and an LX90...haha.
Do keep on capturing it as it grows brighter! [smilie=cute.gif]
