guess what is this and its use?
- orly_andico
You can get EL panels from
Sonia Lim
Nejilock Technology Pte Ltd
Tel: (65) 6785 2345
H/P: (65) 9489 9003
I have actually done up two sizes, one for my C8 and one for a WO90 refractor. I have been using them for quite a while already and seemed to be ok. I will try to post some pictures. ( It's been a while since I posted pics and have to go figure out how to do it.)
Craig Stark has a very good article on this - http://www.stark-labs.com/craig/article ... TT_ELF.pdf. I got my idea from here.
Sonia Lim
Tel: (65) 6785 2345
H/P: (65) 9489 9003
christopher
i have gotten the EL directly from Gerd Neumann. As long as the EL emits a broad continuous spectrum, it can alsi be used to take narrowband flats which was my intention. Line emission sources don work as well. The light is left on only when taking flats. It is removed totally when taking the object of interest. Really like the flat profile of the EL panel...makes transportation easy, can be placed in the same bag as the refractor during expeditions. One thing of note however, the inverter does make a high frequency (though not that loud) sound. I guess the method of electro-luminence requires the generation of high voltages which is generated within a converter circuit that is connected to the EL panel when the light is activated. More information on EL here.
These are the two EL panels I framed up using hardboards from the stationery shops. The EL panels, including the inverters, can be bought from Nejilock Technology. The one on the left is for the WO90 scope and the one on the right is for the C8.
[img][img]http://farm7.static.flickr.com/6187/604 ... 312912.jpg[/img] EL Panels for taking flats by mch3898, on Flickr[/img]
Below is one of the master flats taken using the above EL panels.
[img][img]http://farm7.static.flickr.com/6203/604 ... 77ef8a.jpg[/img] master flat by mch3898, on Flickr[/img]
Hope the above is useful for those who want to DIY these very useful accessories to your imaging.
christopher
- cloud_cover
