WTS: Celestron #52268 C90 maksutov OTA - SOLD
- Favourite scope: maksutov
http://www.celestron.com/browse-shop/sp ... ting-scope
I made a DIY nylon flock roll to insert into the 16mm baffle tube for improving contrast.
The effect is very noticeable in daytime, maybe a little for the Moon, planets probably not. Solved the flare loop problem with bright star and planet outside eyepiece FOV.
It is very safe against slipping into the tube , can be removed by hand , use a stick to guide it back in.
Review here
Youtube commercial 1
Youtube commercial 2
OTA weight 1.7kg.
Solid all metal construction.
Vixen dovetail is 75mm long with 3 circle pits for non-slip.
2 very small paint chip at the front metal circle where the dust cover sits. I covered it with black marker pen.
Scope is kept in dry cabinet. Minimal dust.
I used this scope to view the 5 brighter planets at 100x magnification.
No mount no finder no eyepiece
1.25" 90degree mirror diagonal , front & rear dustcaps , original "child size" celestron backpack included
Price $250
Self collect at choa chu kang MRT.
Last edited by Hardwarezone on Sat Aug 09, 2014 12:44 pm, edited 2 times in total.
Re: WTS: Celestron #52268 C90 maksutov OTA - with contrast m
Bump for you. 90mm MCT is a good design to consider if portability, collimation-free and tight budget ranks highly in one's priority list.
Thanks for the link to the review. Very interesting to read Ed Ting's conclusions of C90 vs the mighty Questar.
Thanks Gary for the thumbs up.
This scope is still looking for new owner.
If you need finderscope or eyepieces, no problem I can buy it for you but there is some waiting time.
Mirror condition
Corrector plate dust condition , paint chips marked 1 2
Reduced---
*update 8pm
scope reserved for Mike.
*To Mike
This is the flare loop that exist in Celestron catadioptric scopes.
http://i.minus.com/ipDMQ4NGLdSRC.png
*update 8pm
*To Mike
