Hello all, its time to start clearing my astro stuff.
The following items in the photo below - items are in used condition (with user marks) unless otherwise stated. :
1) TS Optics 2 inch extension tube 35 mm: S$30/- [SOLD]
http://www.teleskop-express.de/shop/pro ... -long.html
2) Hotech SCA-TA2 2 inch adapter - has a t-thread M42-P0.75. S$40/-(SOLD)
3)Vixen Weight shaft camera bracket - S$40/- https://www.vixenoptics.com/Vixen-Weigh ... p/3796.htm [AVAILABLE]
4) JMI Motofocus NGF-S focuser - S$60/- Please note that this focuser needs some soldering skills - the connector wire to the motor needs to be soldered to work. Will give warranty on this - ie if after soldering, it doesnt work - will refund. The threads on one end of the ADPTSCTL adapter are 2"- 24 female SCT if you have an adapter or connector that is 2"-24 SCT Male then you should be able to couple to it. So one side is your normal 2 inch - the other end needs a SCT adapter to thread to whatever you have. (SOLD)
5) fine tuning XY mount - S$120 - unused [AVAILABLE]. I bought this intending to attach the Vixen Polarie so that I can polar alighment more accurately - never got round to it. Was purchased in Japan - cannot remember what the brand is. Has the typical Takahshi green - but i dont think it is takahashi - maybe someone knows? Threads are 1/4 inch - so it can be mounted on a camera tripod - and the top screw is also a 1/4 inch to thread say onto the Vixen Polarie base.
6) Orion Shorty Plus 2x Japan 3 element Barlow - S$60/- (withdrawn)
7) Vixen illuminated guider GA-4 (Japan) S$100/- (SOLD)
Lot 1 by tuna7777, on Flickr
PM if need better photos - deal at Vivo city at convenient timing. Thanks for looking.
WTS : Astronomy Equipment Accessories
Re: Items to sell
8) Stellarvue F50 RACI Finderscope with 50-60 mm rings with stellarvue shoe (1 nos) on riser block. Please note that the stellarvue shoe is not the same as the vixen type finder shoe. It fits the narrower stellarvue rail. Price reduced to S$150/- cos only include one shoe. [AVAILABLE]
http://www.stellarvue.com/stellarvue-9x ... ck-f050m2/
9) ADM D series Saddle - S$60/- [AVAILABLE]
10) Binoculars tripod adapter : $20/- [AVAILABLE]
11) Orion Ultrablock filter 1.25 inch $30/- [SOLD] https://www.optcorp.com/orion-ultrabloc ... unted.html
Re: Items to sell
Would like to reserve items 6 & 11.
Thanks
Thanks
Re: Items to sell
Hi
Pls reserve item 1 and 8
That is
The 2 ins extension and the finder with
Shoe and mount ing saddle.
Pls pm phone to arrange for met up . Thanks.
That is
