I have 2 EQ3-1 for sale:
1. Old EQ3-1 gray color with aluminum tripod (SOLD)
2. EQ3-1 black color with aluminum tripod (SOLD)
Heaviest scope i used this with is my 150 f5 newt, and i think that's the max it should take.
I managed to get an EQ4 hence the sale.
Its way better than an EQ2 and will easily be a good replacement for the stock mounts of 80mm long refractors or 114mm long newts.
Comes with matching dovetail bar.
Pictures:
https://imgur.com/gallery/WzFGO
3. Celestron EQ1 w/ tripod (w/o counterweight and eyepiece holder)
NA
Came with an 80mm long refractor but honestly this should only accomodate lighter scopes. Convert your light toy scope into a decent one with this by adding a manual tracking capability. Also good for 90mm and below maks. Check the mount specs online to see if you may need diy screws to mount your scope.
WTS : EQ3-1 Mounts [SOLD]
Re: WTS: EQ3-1 Mounts
Hi
Interested in your mount
Can come to your place to actually look at it before deciding? Because not interested in parts made of plastics.I want ALL METAL type of equipment. Pls pm phone so I can contact you.Thanks
Timeline is one week
Pls reply here if you had message me
Otherwise I wouldn't login
Thanks
Thanks
Hi superiorstream. I sent you a pm. Thanks.
Update:
Sent you another pm.
I checked and there are plastic parts mostly on the tripod.
Update:
Can come to your place tonight/daytime.
Pls pm phone and address to work out detail.
Adj crescent is quite near my place
Upzz price reduced with free stuff and additional item for sale
- yltansg
can call me at 9eight 3six6one 32
Interested in EQ3. Thks
Alfred
Alfred
Re: WTS : EQ3-1 Mounts [SOLD]
Sold the eq3 n retracted the eq1. Thanks
