1) William Optic Long Version Vixen-style Dovetail Plate (New, may have slight screw marks as it is attached to ring for a while for test) $80 SOLD
https://williamoptics.com/products/acce ... tail-plate
2) Vixen Manual Operation Clutch (3828)
The manual clutch allows the use of the mount’s slow motion controls when the MT-1 motor is installed on the mount. The clutch has a thumbscrew to disengage and re-engage the motor as required. $40
https://www.vixenoptics.co.uk/Pages/mot ... ories.html
3) Takahashi clamshell for FS-60, sky 90 etc, 80mm diameter tube. New $100 (SOLD)
4) Astrophysics adapter plate (Q4044), This adapter will enable you to use AP or Robin Casady saddle with your EM-10, EM-200, Teegul and other Takahashi mounts; Giro2DX or any mount that has, or can be adapted to have, a 2-hole M8 mounting pattern on the top of the declination axis. The two holes are spaced 1.378" or 35 mm apart. The four outer holes are tapped 1/4 - 20 to accept the Astro-Physics plates. $50 (SOLD)
http://www.astro-physics.com/index.htm? ... ing_plates
5) Takahashi Barlow 1.25", 2x (mint condition but box is not tip top condition due to storage) $120 SOLD
FS: Mounting hardware & Takahashi barlow (SOLD)
- KKK26
- Attachments
- Tal barlow.jpg (60.16 KiB) Viewed 1370 times
- manual_operation_clutch.jpg (4.32 KiB) Viewed 1386 times
- m-pv-l_02a.jpg (26.89 KiB) Viewed 1386 times
- IMG_5564 - Copy.jpg (58.63 KiB) Viewed 1386 times
