Have a Trius SX25C OSC CCD that I have never used, other than to try darks and bias frames at home.
This is the latest current TRIUS version with the 3 mini-USB2.0 hub version.
Additional cooler fan included.
NEW = USD$3350 or SGD$5000(if GST 7% added)
Asking a very reasonable price, now REDUCED toSGD $2800
PM me or Whatsapp 9six-92,,44..eight=7 for enquiries.
Thanks!
NB- All cables, adapters etc are original and included, with blue case and CDrom also.
Trius-SX25C
Major features:
Very large, high resolution 'SuperHAD' CCD chip, with 6,000,000 x 7.8uM square pixels in a 23.4 x 15.6mm array. Size equivalent to APS film.
Single-shot colour, using a Bayer matrix of R, G and B on-chip filters. No filter wheel required.
Triple USB hub for accessories, built-in.
High performance two stage cooler for better than -35 C chip temperature reduction.
Dry Argon chamber fill for improved cooling performance.
Exceptionally low dark signal - No dark frames necessary for most deep sky objects.
Exceptionally effective anti-blooming with minimal effect on linearity and no lost active area.
High sensitivity, equivalent to 60% QE at peak of green filters.
Back focal length 17mm +/-1mm.
NEW! Built-in super high speed USB 2.0 interface (USB 1.1 compatible) for approx. 3.5 second downloads.
Built-in autoguider output.
Single USB cable control for all features - get rid of that dangerous cable tangle!
Only ONE computer needed to control all of the devices and functions.
Very low power consumption. Less than 1.5 amps at 12v DC.
Compact and lightweight - only 75mm in diameter x 100mm long - less than 500 grams load on the 'scope!
WTS - Starlight Xpress TRIUS SX25C (OSC CCD)-REDUCED!
Twinkle twinkle little stars,
How I wonder what you are.
Re: WTS - Starlight Xpress TRIUS SX25C (OSC CCD)
Please note whatsapp contact has been amended:
Re: WTS - Starlight Xpress TRIUS SX25C (OSC CCD)-REDUCED!
Price REDUCED to $2800!!!
