WTS: Skyrover 70SA and latest version of HEQ5---all sold
tommy
Favourite scope: 70sa
Post by tommy »
Hello , folks
Here is my scope and mount which i have just bought at JAN 2019, bcz of my busy work, i have NEVER got any chance to use them, they are all in perfect condition.if you are a visual guy, it's not for you at all , if you want to do some imaging, the whole rig is dedicated for it
1 Skyrover 70SA
A super flat field PETZVAL scope with 4 lens built in, which is similar to the structure of fsq106, which gives it a purely flat field with huge image circle of 45mm diameter, you can use any type of full frame camera up to it, and the stars are pinpoint cross the whole field, if you are not familiar with this brand , check this out :https://tlkw79.wordpress.com/2018/05/20 ... -70sa-iii/
also here are some images taken from a famous chinese astrophographer using 70sa and qhy16200:
https://www.flickr.com/photos/62298933@ ... 620771210/
brand new ask for 800 SD
including
1.OTA with sturdy dual speed 2.5inch focuser
2. camera tilt unit
3.tube ring and plate
OTA with ring tube
camera tilt unit
2 heq5 pro
the latest version of heq5 including tripod, battery, 2 counter weights(5kg + 5kg), hand control, some cables you may need to connect to computer
brand new ask for 1000 SD
if you are interested in any of above. plz contact me :91309685
feel free if you want to take a look at it , i live in clementi
Re: WTS: Skyrover 70SA and latest version of HEQ5
Hi Tommy,
You did not correctly attach the photos, hence they are not displayed. Do check your settings and try again if you want to show your items. Cheers
tommy
Post by tommy »
Airconvent wrote: Thu Jul 04, 2019 9:57 pm Hi Tommy,
thank you , issue has been solved
tommy
Post by tommy »
bump!
HEQ5 price reduced to 900
tommy
Post by tommy »
bump!
heq5 reduced to 800, anyone ?
ethanwyh
Favourite scope: Sharpstar SCA 260
Post by ethanwyh »
tommy wrote: Thu Jul 04, 2019 11:10 am Hello , folks
1 Skyrover 70SA
including
2. camera tilt unit
OTA with ring tube
camera tilt unit
2 heq5 pro
hi there, is the skyrover still available?
kochu
Post by kochu »
Hi
Is the HEQ5 Still available.
Kochu/MOB: 9103971
kochu
Post by kochu »
No reply yet . Is this a genuine posting?
ethanwyh
Post by ethanwyh »
In case you missed it, he stated his contact number for a reason?
Contacted him once for the 70 SA, quite responsive on phone and not here.
kochu
Post by kochu »
Yes
I have done that also
