D:76.2mm F:910mm refractor. S/N 32148. Scope label is Moonstar. Lens has small minor chip at the edge (7 O'clock position is photo) and not affect viewing.
Lens has some dirt and can see coating peel off some area as a vantage aging scope. It still can produce beautiful images. It would be great as collector item.
Mount is incomplete (missing bottom part and tripod)
There are solar viewing device, 2 diagonal, several eyepieces with sun and moon filter attached, straight through diagonal etc as shown in photo.
Wooden case is bad condition and heavy/bulky. What you see in the photo is what you will get.
$150, collect at Woodlands
WTS : Vintage Danchyka 76.2mm refractor with incomplete mount (SOLD)
- KKK26
- Attachments
- R5.jpg (35.43 KiB) Viewed 1918 times
- R4.jpg (38.89 KiB) Viewed 1918 times
- R3.jpg (36.87 KiB) Viewed 1918 times
- R2.jpg (23.13 KiB) Viewed 1918 times
- R1.jpg (36.04 KiB) Viewed 1918 times
Re: WTS : Vintage Danchyka 76.2mm refractor with incomplete mount
Hi
Can I just take all without the wooden box......only mrt as transport .....no car.Pls check if tube of telescope is iron or aluminium. If iron pls indicate. Willconsider discarding also.
If ok pls reply and message your phone to arrange for metup.
If it had been reserved pls indicate . Thanks.
- KKK26
yes reserved for you. it is aluminium tube including focuser. Thanks
