FS: Dry cabinet 1300 Liters (SOLD)
Akarui dry cabinet
Model: D1336E
Capacity: 1300 Liters
Dimension: (W120 x H196 x D66) cm
(take note: it is super huge cabinet with basic analog control, RH% wont go below 30%)
It has 5 heaters (2 at top and 3 at bottom) . New 12V DC power supply unit is replaced recently. Heaters use 12V supply and very low watts for energy saving. Due to huge size & lower heater wattage, it needs several hours to bring down RH% to 40-45% in initial start up. After that, it is stable at 40-45% with 2-3 heaters.
Cosmetic condition is 7/10. No major user marks and scratches, crack etc.
Shelving can be relocated as per own preference.
Door seal are good condition (RH remains at 50% 2 days after shut down) and it has key & lock. And 4 wheels for easy movement.
Buyer may do improvement:
1) Install door magnetic like newer model dry cabinet door
2) may install light inside cabinet
Price: $800
Self collect at my home near Admiralty mrt (it has wheels and can push easily but need manpower to load /unload into van)
Re: FS: Dry cabinet 1300 Liters
I have installed 2 nos of Digital controller which can cut in/out dehumifier units for better control and energy saving.
