STARMATRIX has a used Vixen VC200L OTA in PRISTINE condition, like NEW. Mirror is clean, and OTA has very little cosmetic flaws except for a few marks on the dovetail plate.
More about the VC200L:
The VC200L’s catadioptric VISAC (Vixen Sixth-Order Aspheric Cassegrain) optical system is one of the most sophisticated optical designs available on the market today: free of coma, curvature of field, spherical and chromatic aberration. Especially noteworthy is its sharpness and flatness at the edge, which far exceeds that of Schmidt-Cassegrain systems of the same aperture. It provides a pinpoint star image less than 15-microns, even at the edge of its 42mm image circle. If you are looking for an astro-photographic catadioptric, this will be an excellent choice.
The VISAC optical system is composed of a concave primary mirror, a convex secondary mirror and a three-element field corrector at the base of the focuser. The primary mirror is a unique innovation: a precise sixth-order shape produced by Vixen's High-Precision Poly-Order Aspherical Mirror Molding Technique.
The VC200L is well suited for observation and astrophotography of the moon, planets, star clusters, nebulae, and comets. The rack-and-pinion focusing mount accepts optional 2” eyepieces and accessories.
The VC200L OTA comes with the standard dovetail plate (so that you can use it directly on Vixen dovetail-based mounts or even the Portra. 6x30 finder is included, together with the 1.25" visual adapter.
SGD$1700.
Our website has a new USED equipment section for your reference: www.starmatrix.biz/smused.php
Brought to you by STARMATRIX SINGAPORE
WEBSITE: www.starmatrix.biz
SALES: sales@starmatrix.biz
ENQUIRIES: info@starmatrix.biz
PHONE: +65 8112 5806
STARMATRIX:used VC200L OTA available now!!
- Vendor
