Newbie need help to start
Noop
Favourite scope: Beginner's scope
Post by Noop » Mon Jul 18, 2016 1:14 pm
Hi All,
I'm new to the hobby after several years of interest. Recently got myself a XLT 150. I tried looking at the moon but view looks blurred even after focusing. Currently using the stock 25mm eyepiece. Is there something amiss? or some equipment i need?
Thanks in Advance.
Noop
Hardwarezone
Favourite scope: maksutov
Re: Newbie need help to start
Post by Hardwarezone » Tue Jul 19, 2016 11:45 am
Likely the mirrors are not aligned (collimated)
Another tip is use a clothespeg on the focuser wheel for fine control, credits to eric63
http://www.cloudynights.com/topic/54139 ... ?p=7298426
antares2063
Favourite scope: Newtonians
Post by antares2063 » Tue Jul 19, 2016 8:22 pm
This is a very rough way of gauging but, take out the eyepiece from your scope in the day time, look down the focuser and see if your secdonary mirror silhouette is in the middle with the 4 vanes roughly equal length.
Also , u can take a look at this:
http://www.astro-baby.com/collimation/a ... 0guide.htm
Regards
Junwei
Post by Airconvent » Tue Jul 19, 2016 10:11 pm
Guys, for such a short focal length, the scope must be way out of collimation to show a blurred moon with a 25mm eyepiece. Am I wrong?
Noop, did you buy this brand new ? Did you colliminate the scope as per the instructions in the manual? Is everything installed as per what the manual shows ? Have you tried checking it out in the day time on a terrestrial object ? (Image would likely be upside down, so that's normal).
Noop
Post by Noop » Wed Jul 20, 2016 11:38 am
Thanks all for the reply!
I bought this second hand, and everything was pre installed.
I believe it needs collimation.
In the daytime I tried looking at terrestrial objects, it focuses on objects about 15 metre clearly.
antares2063
Post by antares2063 » Wed Jul 20, 2016 6:11 pm
ok, try your best to tweak it. For solid tube newtonians, 95% of the time its always only the primary that needs adjusting.
and welcome to the hobby..haha
regards
Junwei
