WTS : SKB Military Dry box with cube foam [Closed]
Karl
Favourite scope: 8"EdgeHD XLT f/10, WO STAR 71mm f/4.9
Postby Karl » Mon Mar 03, 2014 10:25 pm
CONDITION : Brand new, (never been used, spare one)
PRODUCT : Military Standard Dry Box inclusive of cube foam
Original Retail Price: S$565
Selling for [Reduced] SGD 250, pm/nego if interested * updated 04/08/14
Suitable for 8 inch Schmidt–Cassegrain (OTA) or smaller
BRAND : SKB
MODEL : 3I-2317-14BC (I-series)
PICTURE URL: http://www.skbcases.com/industrial/prod ... xSGqhSSzh6
DESCRIPTION
SKB Cases Mil-Std Waterproof Case - 23" x 17" x 14" (L.W.D) is a fully submersible case that resists corrosion and impact damage.
The SKB 3I Series of waterproof cases are the perfect solution for storing and transporting your delicate electronics, A/V equipment, microphones, mixers, cables, computers or percussion and music accessories. Most sizes of these SKB Dry Cases are available with a variety of interiors to accommodate the needs of the traveling musician. Interior options on most models include cubed foam, layered foam, padded dividers, or an empty interior. The SKB 3I Series Injection Molded Mil-Standard Waterproof Cases are molded of ultra high-strength polypropylene copolymer resin, featuring a gasketed, water and dust tight, submersible design (MIL-C-4150J). It features a continuous molded-in hinge, patent pending "trigger release" latch system, comfortable, snap-down rubber over-molded cushion grip handle, automatic ambient pressure equalization valve (MIL-STD-648C), and resistance to UV, solvents, corrosion, fungus and impact damage (MIL-STD-810F).
Specifications for SKB Cases Waterproof Military-Standard Case - 14" Deep :
INSIDE DIMENSIONS
Lid Depth 2.50 in / 6.35 cm:
Base Depth: 11.50 in / 29.21 cm
Interior Length: 23.00 in / 58.42 cm
Interior Width: 17.00 in / 43.18 cm
Interior Depth: 14.00 in / 35.56 cm
OUTSIDE DIMENSIONS
Exterior Length: 25.63 in / 65.09 cm
Exterior Width: 19.50 in / 49.53 cm
Exterior Depth: 15.63 in / 39.69 cm
OTHER PROPERTIES
Color: Black
Product Weight: 9.39 kg
Max. Temperature: 71.11° C
Min. Temperature: -40.00° C
Features of SKB Cases 2317 Waterproof Military-Standard Case :
1. Industrial strength injection molded pull handle
2. Four wide set in-line skate style wheels for easy transport
3. Trigger release latches can be retrofitted with TSA accepted key locking latches
4. Padlock holes include stainless steel padlock protector clips
5. Waterproof and dust tight design (MIL-C-4150J)
6. Continuous molded-in hinge for added protection
7. Trigger release latch system
8. Snap-down rubber over-molded cushion grip handle
9. Ambient pressure equalization valve (MIL-STD-648C)
10. Resistant to UV, solvents, corrosion, fungus (MIL-STD-810F)
11. Resistant to impact damage (MIL-STD-810F)
Karl
Re: WTS : SKB Military Dry box with cube foam [Reduced $250)
Postby Karl » Tue Mar 25, 2014 4:20 pm
Updated 25/03/14 to $ 300
Karl
Postby Karl » Mon Aug 04, 2014 9:28 pm
Updated 04/08/14 to $ 250
wind
Favourite scope: Nil
Postby wind » Fri Aug 08, 2014 3:41 pm
PMed you Karl. Looking forward to your response. Cheers
Karl
Postby Karl » Sat Aug 09, 2014 3:52 pm
Sold, this thread is closed
Return to Pasar Malam
Who is online
Users browsing this forum: No registered users and 2 guests
