Takahashi Sky-90 - which mount?
davidyeo@yahoo.com
Favourite scope: None
Post by davidyeo@yahoo.com » Sun Mar 13, 2016 8:10 pm
I have just 'inherited' a Takahashi Sky-90 from a friend. What kind of Goto mount do you all recommend? Something portable would be great.
I am relatively new to astronomy.
Thanks.
ivan
Favourite scope: 448.3 inch Segmented Ritchey Chretien Telescope
Re: Takahashi sky-90 - which mount?
Post by ivan » Sun Mar 13, 2016 10:59 pm
Hi David,
Do you intend to do astrophotography or just visual observation?
davidyeo@yahoo.com
Post by davidyeo@yahoo.com » Mon Mar 14, 2016 4:32 pm
Visual only.
davidyeo@yahoo.com
Post by davidyeo@yahoo.com » Mon Mar 14, 2016 4:34 pm
I asked about the Nexstar evolution goto mount but I think the telescope will not be to clear the eyepiece tray because of the length.
Re: Takahashi Sky-90 - which mount?
Post by Airconvent » Mon Mar 14, 2016 10:20 pm
The Nexstar mounts usually come as a complete set unless someone willing to break his system up. I think Idris has a "spare" original Nexstar 8i mount. I can check with him if he is interested to let it go. Otherwise, you can check out the Ioptron range. They do sell budget goto mounts that is suitable for your setup.
geyes30
Post by geyes30 » Mon Mar 14, 2016 10:33 pm
I have a cheap Ioptron Cube mount and although it is super portable and easy to set up, it struggles to even keep up with the weight of an Orion ST-80 (the clutch is plastic, so I don't ever tighten it too much). Don't know about the weight of your scope but I'd look elsewhere if I could do it all over again.
