Could C90 be fitted with tube ring
garygoh
Post by garygoh »
Any C90 owner have try to add tube ring to their C90 scope before, I want to mount the scope onto a vixen portal 2 mount but the finder scope will be at the bottom left once I mount it onto the portal 2. If any of you have mounted a tube ring to your scope, can you give me the brand and the model name of the tube ring thanks guys.
Hardwarezone
Favourite scope: maksutov
Re: Could C90 be fitted with tube ring
Post by Hardwarezone »
IIRC the rear oversized cell have a U cutout to accommodate the rear of the dovetail .... means no room left to put tube ring *unless the original dovetail is removed from the tube.
