I've been considering getting an equatorial mount as a replacement for my Alt-Az mount.
It seems like some of the mounts like the EQ6-R can't reach our 1 deg north latitude and a custom built wedge will be required.
Would anyone have advice on where to fabricate such a custom built wedge if the manufacturer doesn't produce one?
Thanks!
Fabricating Low Latitude Wedges for Equatorial Mount
- SebastianTai
- Vendor
- Favourite scope: Officina Stellare Pro RC 800
- Location: 137, Jalan Pahang, Setapak, Kuala Lumpur 53000 Malaysia
Re: Fabricating Low Latitude Wedges for Equatorial Mount
I do offer service of designing wedge using CNC plates, normally for EQ6-R I do offer wedge as package with purchase
- orly_andico
I had a CGEM once and had a machining company in Malaysia make me the wedge. It cost over $300.
There are some local companies in SG that can also make you a wedge, but expect similar pricing.
I have a Tak EM-11 that can't reach 1 degree, I used to deal with this by shortening one tripod leg but it looked dangerously unstable. So something I will try soon is to 3D print a wedge. The plastics used in 3D printing are pretty strong in compression (particularly at 40% infill or higher) and my EM-11 will not carry more than a 4-5kg telescope, so worth trying.
An EQ6 is a different story. That said, I once made a wedge out of two chopping boards and some pine wood from Home Fix. Worked fine on an AP600 with over 15kg of payload.
Thanks for your suggestions. 3D printing is an interesting idea.
