Hi Alfred
Very hard to get someone engaged in daily obs of the sun because of the heat on prolong exposure to the sun. Also its pretty uncomfortable., and those solar scope/filters are not cheap.
Moreover, after prolong(approx 11+ years) exposure to the sun, I learn that even optical coating turn into cataract! It happens to my 8 cm refractor, bought new from astroscientific.
Now for today's observation.
In 540nm.... Sunspot 2810 show up as 2 spots separated by a lightbridge.
In Ha...... 2 bright spots in the northern belt., one at 2810 location and another with no spot visible.
No bright region detected in southern belt.The prominence that showed up today are pretty small. Also one small filament seen near the bright region in the northern belt and one near the middle of the southern belt.
In Cak...... Besides the 2 regions mentioned above shows up in also cak., A BRIGHT REGION SHOW UP IN NEAR THE CENTRE OF THE SOUTHERN BELT..... a surprise.
Observed between 10am to 1 pm.
Solar cycle 25
Re: Solar cycle 25
Today sun......
Almost total blackout in all activities.
At 540nm..... No sunspot., blank sun.
At Ha 0.5A bandwidth...... A very very small prominence at northern belt edge rotating out of view., followed by a small filament. No bright region at all.
In Cak..... The above region in the northern belt show up in cak with 2 bright spot. That all.
Overall, the show of activities in this cycle is very low., and hence very different from other cycles I had observed.
- yltansg
Re: Solar cycle 25
Thanks Mr Chia for the update on the Sun on 2 Apr.
Here is a belated posting on the images taken on 20 March.
This Hydrogen-Alpha image was from Global Oscillation Network Group (GONG). It showed the position of Active Region 2810.
The following images are taken by me using a Celestron 11" SCT.
Fitted with a Daystar Quark H-Alpha eyepiece, Chromosphere Model, my C11 produced this zoom-in image of the filament and the nearby Active Region in H-Alpha, :
Using a set of Calcium-K filters fitted on the same C11, we can see the lower chromosphere lighted up by Calcium atoms:
And this is how the Calcium full disk looked like from GONG:
Alfred
Alfred
Re: Solar cycle 25
Thanks Alfred for the nice and detailed zoom in photos..
However, up to now, I notice this cycle 25 is drastically different from the past 3 that I had observed.
One is that activities had on several occasions die out completely..... Like now.
Another is that even prominence is a no show..... Only always small and similar to those at the beginning of every cycle., not to mention that the sunspots are small and frequently Featureless.
Only super zoomin like Alfred s photo show interesting features. Thanks Alfred.
