Oh dear.... I'm sad to see two forum friends get annoyed at each other.
I'd like to weigh in on this with my thoughts:
Mooey, that's fantastic advice you've given. In fact I was wondering which guiding setup myself and am toying with using a 50mm guider (someone loaned me his SSAG/50mm). I'm using a Vixen type holder, so no issues with flexure there.
Thanks for pointing out that its good for down to 1.5arcsec/pix. That's pretty useful information!
As an aside, the cheapest kwik-adapter is found at
WWW.MODERNASTRONOMY.COM which will ship to Singapore for 28GBP. You will need your own 50mm finderscope though.
Personally I'm not a fan of the Nexguide/80mm. Nexguide sounds like a good idea and it is, if you don't want to bring a laptop into the field. Unfortunately its sensitivity is so poor I had issues locking onto a dimmer than Mag 4 star in the darkish skies of Sedili using an Orion ST 80mm with 2 secs exposure. That's poor performance. On the other hand, the SSAG found plenty of guidable stars with a simple 50mm finderscope in the bright skies of Singapore at 0.5sec.
I'd like to point out though, that because you're using a C8 with a FL of 2000mm, even a camera with largish pixels of 8.4um (my D700. Most APS-C sized cameras are about 5+um), that works about to 0.8+ arcsec/pix, which is well below the minimum resolution suggested by Mooey. Thus in your situation I'm not so sure how well the SSAG/50 will work.
On the issue of mounts, I think Orly has brought up a very valuable point.He's recently had to troubleshoot his mount for severe PE issues hence he's keenly aware of the complications of mounting issues, but its a very valid point. I noticed you're using a C8 on a CG-5 mount, which while a decent mount, is also probably overloaded for photography when you're plonking a C8, guidescope, camera and etc on it, so its also true that your mount may let you down even if you solve your guiding issues.
I would strongly urge you to consider getting a shorter scope (be it a smaller newt or a refractor) and go down in focal length if you're starting out. This would obviate most mount issues and also allow you to use the much lighter and convenient SSAG(or QHY5)/50mm guider.
Also, most objects will be well framed in a shorter refractor while a C8 is generally good for small objects. Its FOV with a cmera is pretty small!
Just my 2c
