Widefield Sagitta Constellation with M27 and M71
celeron787
Post by celeron787 »
Another clear night yesterday 19/07/2020.
Went for the Sagitta constellation as I could fit the whole constellation in 1 frame, with M71 in the middle. Was surprised to see M27 also pop up in a single 15sec sub. Apparently there's a few more super tiny planetary nebulae like NGC6886 within this frame, not as big as M27 but pointed out in online plate-solving.
View plate-solved version here: http://nova.astrometry.net/annotated_full/4392132
Sagitta is a dim but distinctive constellation in the northern sky. Its name is Latin for "arrow". Located between Beta and Gamma Sagittae is M71, a very loose globular cluster mistaken for quite some time for a dense open cluster.
Located a few degrees north from Sagitta in the nearby constellation Vulpecula, you can see the Dumbdell Nebula M27 which is a planetary nebula.
Equipment
Sony A6000
Samyang 135mm F2.0
Sky-Watcher Star Adventurer
Tripod
Acquisition
Bortle 8
ISO400
Light frames - 235 x 15secs
Dark Frames - 30 x 15secs
Flat Frames - 33
Bias Frames - 50
Software and Processing
Deep Sky Stacker
Photoshop - Levels stretch, gradient removal using Dust and Scratches filter, crop, levels stretch, luminance mask, curves adjustment, star reduction
Lightroom - Adjusted highlights and saturation
Re: Widefield Sagitta Constellation with M27 and M71
Thanks for sharing. The Dumb-bell is quite distinct in your image! :)
celeron787
Airconvent wrote:
Mon Jul 20, 2020 9:12 pm
Thanks! Was also surprised to see it that distinct. I was under the impression that it's super faint object, not possible to capture under our light polluted skies and with such wide focal length. I'm glad that I'm proved wrong, maybe it's because the samyang sucks in so much light. Might go for andromeda next, quite optimistic about that.
Go for it! :)
celeron787
Re-processed data using StarTools.
Better Starfield for this one :)
hhzhang
Favourite scope: 115mm APO
Post by hhzhang »
Very sharp stars from corner to corner! Gorgeous starfield.
celeron787
hhzhang wrote:
Sat Jul 25, 2020 9:57 pm
Thanks! Still learning how to do post-processing, you can have so many iterations of 1 image that it's quite hard to decide on 1 that you like. Trying hard not to go overboard on the processing.
heyjojos
Post by heyjojos »
Nice shots! I can really see the difference before and after stacking!!!
I have never really been very successful with DSS. I use a mac computer and it somehow doesn't work well even when you have an emulator. Don't know of any other software that does stacking.
