Dobs Mount for C8-NGT
ggodetucsamoht
Post by ggodetucsamoht »
Hi Guys, just to share some pix on diy dobs base for my 8" newtonian. Tired of typing all the making process hence maybe you just wanna drop me some feedbacks. thanks.
bornfree
Re: Dobs Mount for C8-NGT
Post by bornfree »
nice! saw it in action twice! very smooth operation! now thinking if there is anyway to custom make a trolley to pull the base around.. hmm..
Born to be Free
Please type the making process. :P Just kidding. :)
Awesome DIY! Participants of the recent SAFRA event had a good look of Saturn through it! [smilie=good-job.gif]
cataclysm
Post by cataclysm »
Wow, very nice customisation !
ggodetucsamoht
Thanks guys for all your compliments. After some usage I still find somehow the mount isnt perfrom to what it suppose to be. Seems like it cant balance after my telrad and 9×50 finder add on.
cloud_cover
Post by cloud_cover »
That's quite normal. You might either want to shift your tube rings upwards if the bottom doesn't hit the ground board or add counterweights to the base.
ggodetucsamoht
cloud_cover wrote:That's quite normal. You might either want to shift your tube rings upwards if the bottom doesn't hit the ground board or add counterweights to the base.
I have tried balancing for normal obs altitude and it perform well, but once come to viewing straight at or near zenith the scope start to fall back and i got to release the tube backwards. As such whenever i need to change viewing angles then i need to readjust the balancing again. If i remove the 9x50 finder then it is able to balance without any readjustment.
I have also come across some specs while designing the dobs mount but to mod it is as good as re-build another set then this unit will be put to waste. unless someone don't mind taking my dobs mount and i can make another new mount. Infact i am more than happy if anyone can get the whole scope from me and i can go for 10" instead..haha
cloud_cover
Falling backwards as in going beyond Zenith? Then that would be because your tube is backward heavy. I see you have both a Telrad and a 50mm finder (total about 2lbs) bolted on to the top of your scope. When horizontal this makes very little difference but when vertical because the moment of force from the tube itself is almost zero (weight x perpendicular distance from pivot) while that from the Telrad/Finder is significant.
3 solutions:
1. Remove one of the finders. Truthfully you don't really need 2 kinds of finders. Or buy a much lighter red dot reticle and /or a 30mm finder (both on sale by ian, I believe)
2. Add counterweights to the opposite side of the tube. Sounds like you only need to weight out the finderscope
3. Increase the stiction of the bearings. This may require roughing up the bearings a bit or applying some friction material such as felt. Disadvantage is that thick material may cause some settling when coming to the end of a motion, resulting in not quite pointing where you want to, similar to backlash.
Hope it helps! :)
ggodetucsamoht wrote:Infact i am more than happy if anyone can get the whole scope from me and i can go for 10" instead..haha
Post a thread in Buy & Sell and state your price. I suspect you may have potential buyers since shipping a 8" inch solid tube dob from overseas will cost quite a bit.
ggodetucsamoht
That's will be marvellous. After i get to know someone who own a 10" dob and looking thru it does amaze me by alot hence i am letting mind to run wild now for upgrading to a 10" or even 12 instead....
