Dobs Mount for C8-NGT
ggodetucsamoht
Re: Dobs Mount for C8-NGT
Postby ggodetucsamoht » Thu Aug 22, 2013 12:39 pm
cloud_cover wrote:Falling backwards as in going beyond Zenith? Then that would be because your tube is backward heavy. I see you have both a Telrad and a 50mm finder (total about 2lbs) bolted on to the top of your scope. When horizontal this makes very little difference but when vertical because the moment of force from the tube itself is almost zero (weight x perpendicular distance from pivot) while that from the Telrad/Finder is significant.
3 solutions:
1. Remove one of the finders. Truthfully you don't really need 2 kinds of finders. Or buy a much lighter red dot reticle and /or a 30mm finder (both on sale by ian, I believe)
2. Add counterweights to the opposite side of the tube. Sounds like you only need to weight out the finderscope
3. Increase the stiction of the bearings. This may require roughing up the bearings a bit or applying some friction material such as felt. Disadvantage is that thick material may cause some settling when coming to the end of a motion, resulting in not quite pointing where you want to, similar to backlash.
Hope it helps! :)
Thanks for informative advice.....
1) problem solve which i tried out by removing the 9x50 finder.
2)YEs, i am now thinking of adding counter weight to the opposite side of the tube from the big finder. I am still stuck in the situation of dunno how to add a proper weigh system as i have no intention of drilling on the OTA.
3) Previously i use felt to contact with the PVC cap but it seem not as smooth, change over to 100% plastic contacts with the teflon it somehow satisfy Gary uses. I dont own or have a single experience handling on a dobsonian scope hence i can only get feedbacks from user like him to tell me if my Dobs mount is a Go or a No Go.......
Postby Gary » Thu Aug 22, 2013 12:56 pm
@ggodetucsamoht - Only managed to try manually find and track objects with your dob in wide low-powered views so far. Very smooth so far. But the real test of the smoothness and dampening of the DIY is via high-powered planetary tracking. You can give it a try and see at what high magnifications, manual tracking becomes too frustrating.
cloud_cover
Postby cloud_cover » Thu Aug 22, 2013 1:11 pm
Its a lot of factors but teflon is the most popular "lubricant"
My 14" uses Teflon pads and a sort of slightly rough almost formica like material to interface. Result is decent stiction but very smooth movements. Gary has previously tried manually tracking mine at 450x, smooth enough. On this aspect its a lot fo experimentation and trial - and-error :)
Postby Gary » Thu Aug 22, 2013 1:28 pm
cloud_cover wrote:Its a lot of factors but teflon is the most popular "lubricant"
Your nice collection of wide-field eyepieces made that even easier. :)
ggodetucsamoht
Postby ggodetucsamoht » Thu Aug 22, 2013 1:54 pm
Ohhh, you are also having a dobs with you then it is my pleasure to give your dobs a visit and do some molest on it. I have the source to get that formica materials just that it dont sells in loose piece but sell in so long roll.
I will be doing another dobs mount and see if the new one works better.
Postby Gary » Thu Aug 22, 2013 1:59 pm
ggodetucsamoht wrote:Ohhh, you are also having a dobs with you then it is my pleasure to give your dobs a visit and do some molest on it.
Oh yes. He definitely has a dob. :) Check out his first light report under Milky Way skies: viewtopic.php?f=1&t=11821&p=80927
So welcome to the club!
[smilie=cheer.gif]
Previous
Return to DIY Astronomy
Who is online
Users browsing this forum: No registered users and 1 guest
cron
