DIY Alt-Azi Mount
Ekezial
DIY Alt-Azi Mount
Post by Ekezial »
Ultra Low cost PVC Mount Prototype.
total cost abt 50SGD
just need to find a way to lock the axis ether with clamps or just just plain knobs driven into the "T" joint.
kayheem
Post by kayheem »
Can you show us a pic with a scope mounted to give a perspective of things?
My take is to have a screw thru the T-joint to adjust friction or to lock.
Ekezial
perspective
Post by Ekezial »
this is a shot with a CD if u need a perspective view of the size
scope is mounted on the side with the Din rails.
here's a list of items u need to make your own.
1x 32mm PVC "T" connector
4x PG29 Cable glands
4x 6201 bearings
8-10x M12 nuts
2x 1 foot 12mm threaded rods
anyway u can easily change the size of the mount depending on the size of the bearings that you use.
kayheem
Post by kayheem »
Where did you get the bearings from?
Ekezial
Post by Ekezial »
well you can either get them at RS(www.rssingapore.com) which is kinda expensive or u can get them at some hardware shop in simlim tower
i got mine in malaysia which cost abt RM8.20 each.
this is the exact model that i got from FAG
6201RSR
Ekezial
mount with scope
Post by Ekezial »
Here's a pic with my scope,had to use a vice to clamp it since i dont have a tripod in my office.
qu1xs1lv3r
Post by qu1xs1lv3r »
any chance the author can upload the pix again?? hehe
