need help for lighter weight tube making(closed)
michael
Post by michael »
hi,
Closed...
kingkong
Post by kingkong »
i always thought aluminium is the only viable choice for rigidity and light weight. are there others with superior characteristics?
Post by Meng Lee »
If you have the captial, you can try carbon fibre.
kingkong
Post by kingkong »
won't carbon fibre flex?
either aluminum or carbon fibre will flex. you need to have it rolled (for aluminum tube) or put custom-machined end rings to strengthen it. A 12" OD, 60"L CF will cost ard $1500.00 (not worth it unless you're making a premium scope).
See here for alternative: http://www.singastro.org/viewtopic.php?t=3352
denebman
Post by denebman »
I know a supplier in China who is making 290 mm id, 1.5 mm thickness and 1500 mm long carbon fibre tube for dobsonian telescope. Cost is roughly S$ 600~700. The correct way to make rigid CF tube is to multiple spiral bound it from a mold rather than roll and reinforce it. I am considering to make an 8 inch dobsonian using his 240 mm id CF tube in near future.
Sonoco Singapore Pte Ltd also makes kraft paper sonotubes up to 1000 mm ID however they require a minimum order of 50 meters.
http://www.astronomy.com.cn/bbs/attachm ... update=yes
denebman
Post by denebman »
If you read Chinese, here is the link:
http://www.astronomy.com.cn/bbs/viewthr ... 3%E5%BE%84
Slightly OT, will a 1.5m long tube fit the backseat of a cab?
michael
tube
Post by michael »
hi
thanks for vluble dscn....i am not going fo crbn fiber. i just want to make with alluminium...i think i can get it more easily and cheaper way right?...also not so heavy weight.
Now i need to know which thickness of the wall should be btr for this kind of tube? 1mm,1.5mm or more..?
thank you...
