I'm not really looking for solar filter kinds, it just needs to reflect well (hint, hint). I am actually doing a research project on telescopes, and I need to find mylar sheets with mirror-like finishes, but have absolutely no idea on where to get them. So any ideas, anyone? I don't mind solar filter film, but are large sheets actually available (and can i afford them? Budget is under $50)
The film would be used for a mirror, so smooth reflections are probably the top priority in choosing. I would be starting off with a proof of concept first, possibly about as large as a soda can, and sizing up.
Where to get mylar sheets for mirrors?
- qinjuehang
My $0.02 is it will likely not work very well if at all. Mylar is really not uniform enough to be employed as a mirror, unless you're setting maybe a 1 meter diameter assembly and won't be using it for visual use..but even then.
If you spend some time staring at a sheet of reflective mylar you'll see how serious the distortion of the reflections is. I doubt it would be worth the effort, even if you do a crazy amount of post processing.
For smaller applications a more fun (and productive) DIY project would be to grind and polish your own mirror.
Its possible though highly unlikely that such a grade of reflective mylar exists but I've never seen it before.
If you're dead set on trying, you can look to larger plant nurseries, and hydroponic supply stores locally, most should carry reflective mylar.
- qinjuehang
