Hi all, does anyone know where I can get a piece of metal tray (those used in dry cabinets) cut?
I need to cut it as it is too long to fit all the way in a particular position. The segment to be cut away measures about 28cm by 5cm.
Fuller details here if you are interested: http://www.clubsnap.com/forums/showthread.php?t=630228
I have a very kind offer to help with the cutting using a saw, but if I can, I would like it to be cut by a commercial source so as not to unduly trouble others. If you need where I can get a precision-cut job please let me know. (In fact don't have to be too precise; a rough cut will do.)
Many thanks.
Where to cut metal?
- orly_andico
there are quite a few rows of metal fabrication shops in the Paya Ubi area (where the car / motorbike repair shops are)
I'm sure if you catch them when they're free they will cut for you for a token sum.
Basically anywhere with a miter saw, or if you're daring an angle grinder can do it for you, but some of these shops have full stamping presses and pneumatic cutters.
Actually if I was feeling reckless a large enough pair of metal snips and a lot of sandpaper could probably get the job done also, heh.
