Tempel 1 anybody?
Jin Peng
Post by Jin Peng »
woah, intro abit, RP means republic polytechnic, there have a astro club which i am in charge in....so hope u guys get familiar with the 'RP' term bah. ^.^
really hope my seniors can give me guidance/updates in upcomming astronomy event ^.^
MooEy
Post by MooEy »
not an easy object to find la, i scanned ard the area at tuas yesterday. did not see any extended object. i guess better skies are needed to actually see it. richard may try again later, let's wait for his good news.
too cloudy in singapore to see anything.
judging from the image from hubble, looks very unspectacular in earth-based telescopes...
On Sunday night, David brought Mooey & I to Tuas to try searching for that comet, but due to the thin high clouds, i could not find it with the C8 & 30mm st-80 (50x, 80 deg app. field) or 9x50 finder even after a few attempts of staring at the exact field with averted vision. In fact, the telescope limiting magnitude was worse than mag 8 thru the scope, so even faint stars were not visible. Last night was very cloudy from 8-10pm, so i did not try. Maybe i will try again tonight if the weather is clear.
From my astro software, the expected magnitude of Tempel 1 is 9.65. I usually do not bother unless the sky is absolutely clear, unless I wanted to capture the flash during the collison and I have a Hubble: http://hubblesite.org/newscenter/newsde ... s/2005/17/
Or watch it here: http://www.noao.edu/news/deep-impact/
Cheers!
ykchia
Post by ykchia »
Hi folks:
Keep trying... Just need a break in the cloud at the right place...
I read that the increase in brightness is estimated to be ~10 times. This is an magnitude brightening up of 2.5 [using ( m1-m2)= -2.5log10( 10)] or 9.9-2.5=+7.4 mag - not sure the size though...
Jul3 - 75mm/f.14+mintron, 11pm from my window LM 8.9 stellar
Jul4 - tried 8:30pm - clouded out
Jul5 - ??
rgds
ykchia
Jin Peng
Post by Jin Peng »
hm.....didn't see anything with my binoculars. Well, nowaday skies are bad. haii,sad.
MooEy
Post by MooEy »
not likely to be seen with small binos, this thing is mag 9.7. even with a 8" scope it's not easy.
Jin Peng
Post by Jin Peng »
icic, hm...so after this, when can we see tempel again?
