ariefm71 wrote:hi liu ming, is the two slide tube design able to maintain perfect alignment everytime you use it or you'll need to slightly recollimate? i will definitely go with shorter fl TMB or TOA if $$ is not an issue
like everyone else in this forum, i have a soft spot for a large reflector :-)
In fact, the two slide tube design is not a concern when it comes to refractor. The two tubes have sufficient overlapping (with a built-in compression belt) which upon external compression automatically align the two tubes and make them concentric. At the eyepiece end, the off-axis deviation is easily controlled within star-test limit.
I think most misalignment happened on refractor is with the lens cell, especially on those with cemented design. Once the lens cell is off collimation, it is of no use spending time to improve the precision of the tube. In my opinion, what really matters is the alignment of the optical train before the focal plane, this is why people emphasize so much on the collimation of Newtonian, SCT, MCT and other compound systems, since their secondary mirrors are part of the “train” and do affect on/off axis performance. In this regard, we seldom see a telescope or an instruction that requires its user to use a precisely machined eyepiece barrel. In most cases, a loose and rattling eyepiece barrel still gives excellent results. The fact that refractors are well known for their deadly kept collimation is due to their super rigid and short lens cell, if the glass elements are confined well, they find no way to go out of collimation. In my opinion, the three so-called push-pull screws function more likely to direct the exit light cone nearest to the centre of the eyepiece rather than to serve as real collimation screws.
Besides the compactness of the dual tube design, its storing and safe carrying are also easy. You may choose to store the section with lens in a dry box and leave the rest outside. You may also hand carry this section only and send the rest as luggage during a long journey. Cleaning is also easy because both sides of the lens are accessible.
I am going to make one prototype next year.
