Takahashi on a EQ3-2 mount
IceAngel
Favourite scope: Sky 90
Post by IceAngel »
can i try first then i buy from you??
your one is mounted on which mount initially??
Leslie
*Owner of Antares 93mm Achromat Refractor* :)
-10.11.03-
*Owner of Takahashi SKY 90 Fluorite Doublet Apochromat Refractor* :D
-25.03.06-
Of course you can la... :) That is use for GP and china made GP clone mount
Anyway, have you try whether your Antares tube ring can use on the Sky90... I think that may be the best low cost solution that is available to you if the Sky90 is not too short.
IceAngel
Post by IceAngel »
oh.. GP mount ah, i dun think it can make it, because i got the dovetail from remus is the same one u have got, it cant fit, is too fat..
the Antares tube ring cant fit.. i have tried it.. :( it's too small..
Leslie
-10.11.03-
-25.03.06-
Hmm... If I'm not wrong, Sky90 use 95mm ID tube-ring which is an odd size... :(
May be you can get a 100mm ID tube-ring and use foam to fill up the gaps between the tube-ring and the OTA.
IceAngel
Post by IceAngel »
hmm.. tube ring ah... ok.. i try to ask around.. hehe.. thanks =)
Leslie
-10.11.03-
-25.03.06-
