Hay, great pictures Jeremy & CheeYiun. Whish I could joint the business end of photography like you guy soon. Lot of inertia though; time, money, and procastination.
Planetary imaging is actually not difficult and also not expensive. The requirement is actually quite low... basically anyone with a digital camera (compact digital camera with correct adapter, webcam with adapter and computer or DSLR) and a telescope can do it... Just capture a lots of image and leave the rest to the processing software.
Hi catalysm, like weixing says, it really quite cheap.
All you needed is a camera, which is below a hundred, ( cheap cheap like my acuter ( $50 ) is still alright ), and a simple laptop oy a nearby desktop.
Your mewlon 210 will compensate for the inadequate camera ( just like my setup ).
i did not have tracking motors, i just like jupiter drift in and out of the screen view and collected 100 jpegs as the mewlon collects wonderful planetary views.
Airconvent wrote:Tachyon has to rent an overseas remote scope for his projects and you did better by "renting" a local "walking astro-imager" package!
Oh, you forget - now I also 'rent' the Digital Sky Survey! Heh...
I still think the temperate belts should be on the brownish side instead of green, as i see it on flt-110.
I think on the flt-110 it is indeed more brown, however, on the mewlon it is less contrasty as it is one huge light bucket.
Really appreciate the mewlon and the flt-110, both have it strengths and also weaknessess. Would like to join it up with a heavy duty mount with slow motion gears...
hi river, i like your tutorial link and also John 3-16
