Barrys home made observatory
Barry
Post by Barry »
Kim, it all depends on your budget, materials available, and space that you have avilable. There is so much dependent on personal choice.If you go to the desert dome calculator, there are several templates to choose from. 1V to 6V from memory.
The calculator will give you the lengths of each triangle for a geodesic design, all you have to do is enter the diameter of your desired dome.
1V is not very attractive as the triangles are few and huge. 6V is very attractive with a very round shape, but a lot of triangles to join.
Its lots of fun though!
If you have a big bank account, then you can get it done reosonably quickly. I had a very small budget, and I work so I am restricted to afternoons and a part of my weekends.
It has taken me nearly a year so far, but I think that has been a blessing. I dont think it would have been as satisfying if I had it done quickly.
A man needs a project....
Baz. :D
Robin Lee
Post by Robin Lee »
Nah, my budget is very small. I just want the dome to be able to block the light from my neighbours. They just don't know about how severe is the light pollution to an astronomer. By the way, where can I reach the desert dome calculator?
Edited: I found it by Google Search. May I know what is the benefit with the increasing "V"?
Clear skies,
Robin.
Barry
Post by Barry »
Kim, you could, for example, have a 3 metre dome in a 1V or a 6V.
1V means less triangles, but they are bigger triangles. This looks quite ugly in my opinion.
6V means a lot more triangles, they are a lot smaller triangles, giving a more "Round" finish or effect.
My dome is 3 metres in diameter and I used a 3V.
Baz :)
Robin Lee
Post by Robin Lee »
Thank you. A 3 metre diameter dome will be big enough for me to put everything inside. Your 3V looks quite good. I will go with this design as well. I have to do my draft now. :wink:
Clear skies,
Robin.
Barry
Post by Barry »
Kim,
You are very welcome mate. I hope you know how to make things out of metal and wood yourself. If not, this is a good way to learn.
I am always here to help mate.
Let me know how you go and dont forget to take photos along the way!
God bless you and your efforts!
Baz. :)
Robin Lee
Post by Robin Lee »
Hey, I have an evil idea now. Is it possible to make a portable observatory? If possible, a foldable observatory.
My concept is that it is made of several of "solar panel" like panels and all of them are joint together using screws or whatever and under every panel, there are wheels.
Clear skies,
Robin.
Barry
Post by Barry »
You can try a fold-up partition style that folds into a flat pack for transport and storage. Alternatively, you can use a standard car trailer, build high walls and a dome on it, make the floor removable so you can put your tripod on the ground inside, then bolt on four wind-down stabilizers, one on each corner.
Robin Lee
Post by Robin Lee »
Can you show me the "You can try a fold-up partition style that folds into a flat pack for transport and storage"? It's quite hard for me to get a standard car trailer as it's almost unavaliable here. Moreover, my garden is big enough for it.
Clear skies,
Robin.
Barry
Post by Barry »
for example. four rectangular frames made of light aluminium or wood, stretch some lightweight black material over them and hinge them together at the sides with metal hinges or some sort of flexible material.
Up to you from there.
Baz.
Robin Lee
Post by Robin Lee »
Ahh.. I got you! :) Is your dome observatory fully functional now?
Clear skies,
Robin.
