try to use the power cable that I gave you. else, it is Positive at the center, negetive outside. I believe there is marking on the scope too.
You might get it "work" but the some component might working under not ideal condition... in short that will lead to shorter life span.
some resources : http://www.nexstarsite.com/
make sure you read the manual first!!
