DSLRs and Astrophotography (Newbie here)
Vince
Post by Vince »
blurblock wrote:
Hmmmm .... maybe I should try to take star trail again ... this time with 10D :) .... ok .... wait for the moon to hide itself ......
10D shoot star trails liao end up with a crapload of extra "stars" (i.e. Hotpixels.)...
I tried shooting Orion again tonight...this time guided and managed to get this photo...
Wow...very nice. I also want to try this in the future. By the way, how long did you guide, what setting did you use and your lens information???
Anyway, have you try the dark frame subtraction?? Your image seem a bit noisy... may be cause by the light pollution???
Vince
Post by Vince »
weixing wrote:Hi,
Hi WeiXing,
Photo details are as followed.
Camera : Canon EOS10D
Lens : 50mm f/1.4 USM
Exposure program : manual
Exposure time : 30seconds
F-Stop : f/2.8
ISO Speed ratings : ISO 400
30 second guided (approximate polar alignment) The camera was mounted on the GEQ tripod with motor drive meant for the Celestron C90.
It's a little noisy because of light pollution, long exposure and high ISO combo. Didn't really do any post-processing except convert the image from Canon RAW to JPEG using Photoshop CS.
You mean you mount your camera on the EQ mount alone??? If this is the case, this is consider unguided. May be you should mount your camera with your C90, so that you can use your C90 to guide and do a longer exposure.
Anyway, I will be trying out wide field astrophotography using my camera soon... hope that can obtain result as good as yours... :)
Vince
Post by Vince »
weixing wrote:Hi,
Unfortunately, I don't have the piggy back for my C90. However, I did take the following pictures prime focus off the C90 with the T-Adapter I purchased.
Vince
Post by Vince »
Moon shot from C90.
hi vince..what's the focal length of the C90? seems the size of the moon looks awfully small for a Mak. For my ETX90 @ 1250mm, even a 40mm eyepiece would just barely fit into the camera's FOV...so your scope has to have a very short FL for such an image..good effort !
I think he use prime astrophotography (without eyepiece)...
Anyway, nice image!!
Vince
Post by Vince »
Airconvent wrote:hi vince..what's the focal length of the C90? seems the size of the moon looks awfully small for a Mak. For my ETX90 @ 1250mm, even a 40mm eyepiece would just barely fit into the camera's FOV...so your scope has to have a very short FL for such an image..good effort !
You might be doing eyepiece projection so there's magnification there. I'm using the C90 as a lens (prime focus photography) so it'll end up being a 1000mm f/11 lens.
The picture of the moon is actually resized. Original size is the one in my avatar...taken off the same photo.
edit : what camera are you using? The EOS 10D has a 1.6 crop factor which mean that technically, the lens is 1600mm instead of 1000mm as per full frame 35mm SLRs/DSLRs.
I can only identify Orion! :shock:
blurblock
Post by blurblock »
Just a question, you are doing prime focusing with EOS 10D .... what lens (the make and diameter) you use to do the prime focusing? Most of my lens are 77mm......
