Advice on taking pics with DSLR
A dark frame is an exposure equal in length as the light exposure and at the same temperature as the light exposure, so that the noise (mostly thermal) is recorded on the dark frame and will be used to subtract the noise from the light frame.
(I kaypoh and ans the question Embarassed )
No problem.
A dark frame is as what Meng Lee mention. A Light frame is the actual frame contains the image.
To take a dark frame, cover lens with the lens cover and cover the DSLR view finder with the view finder cover come with Canon DSLR. Now, with no light able to get into the DSLR sensor, took 10 to 15 frames at the same exposure time and ISO as your light (image) frames. Since you'll be on the mountain when taking your light frame where temperature will be greatly different from day, night and at the ground level, so you must took the dark frames straight or at least asap after your light frames. This is to make sure the dark frame will be taken at temperature around the same as your light frame, so the thermal (noise) map of your DSLR sensor can be subtract away from the light frame using the dark frames.
Traveler
Post by Traveler »
oic....thanks Weixing and Meng Lee! :D
chrisyeo
Post by chrisyeo »
siahheng wrote:Thanks Meng Lee and Weixing. Will not have any tracking equipment for the camera. Just a tripod. Perhaps I can only shoot star trails.
FY - Its somewhere in the French Alps where there is a monastery (La Salette). This trip is organised by my church.
Hi Siahheng,
Don't forget that you can take 30sec-1min shots where the star trailing is not visible and then align and stack them together in Iris.
http://www.singastro.org/web/mediawiki/ ... tal_camera
Once, when I happened to go mountain climbing, I simply placed my camera on a rock on the ground and shot 3x15sec shots Link. No tripod even! My anyhow-technique is to shoot as many images on as high an ISO setting for as long as possible (without star trailing) + dark frames. When you return you can process for noise and saturation. :)
Cheers,
Chris
I was at the French Alps last year and stayed at a cottage in Aravis. Surprisingly, my photos of the night skies were saturated with light pollution. I suspect they were from the ski resorts near Mont Blanc. Hope you have better luck!
siahheng
Post by siahheng »
This is not a ski resort but staying at a Monastery. There will be periods of Silence and Lights Out. Hopefully, it will be dark and not be too cold...(there are no heaters there)
Thanks Chris for the additional info.
siahheng
Post by siahheng »
Dear all, just want to inform you that my two nights at La Sallete was clouded out on the first night and snowed on the second night. Had great fun in the snow but no pictures to show... :(
Thanks to all for their replies.
Siah Heng
Cool... reminds me of the movie "The Name of the Rose"... :P
