yes, both Q4 and T7 are visible in our equatorial latitudes now. T7 being below the circlet asterism of Pisces at mag 4.1 and Q4 is located SSW low at the horizon (10degrees) and is at mag 4.3 It is advisible to watch and search for Q4 early in the evening IMMEDIATELY after it gets dark enough and to have a really clear SSW horizon. I have not personally seen it yet. As for T7, it is visible and appears to be around 10 arc-minutes across and should be around 16 degrees above horizon at 6AM in the morning. Look towards east for it. F4 (Bradfield) is still very low or not even above the morning eastern horizon and is located below the Square of Pegasus with mag of 4.5. T7 can be seen till around 3-4th May where it will dip lower and then re-emerge in the evening sky on 20th May. Q4 will move higher and higher into the sky from now on until it reaches Cancer at around 20th May too. On 15th May, you will notice that Q4 will be right "on" the Beehive Cluster (M44). Interesting!
hope this helps!
