Heh... all assume he has hundreds+ USD on budget...
Jia Siang: You'll definitely need to mount any telescope on a tripod or something for a stable view. If not, you'll tire out your hands and have a very shaky view which usually leads to eye strain and giddiness.
If cost is a very big concern, why not try the Celestron Firstscope? I have no personal experience with it but other users have said its decent and it has its own table-top mount (so you can save on a tripod).
You may also really wish to consider binos. I've just started too, and my budget is also limited. After a viewing session at the Science Centre, I realised that a bino can show you a lot more stars than you can see with the naked eye while still preserving a wide enough view to know which constellation you're in. Then join a obs session with the other guys to borrow their insanely large and expensive telescopes :p
If you have your heart set on the Galileoscope, you'll either want to purchase a tripod, or if budget does not permit, resting the telescope on a beanbag placed on a windowsill (don't drop!) is a better alternative than handheld. If you must handhold, then you will need to brace yourself against some rigid object (such as a wall). Be forewarned: Due to its long length its not easy at all to hand hold or use without securing (as in with a tripod)
Hope it helps and hope to run into you during one of the obs sessions!
