The following are from some website that explain your question:
The light is "redshifted" to longer wavelengths as it rises away from the black hole. So if the object are emitting visible light at some particular wavelength, the observer will see light at some longer wavelength. The wavelengths get longer and longer as the object get closer and closer to the horizon. Eventually, it won't be visible light at all: it will be infrared radiation, then radio waves. At some point the wavelengths will be so long that the observer will be unable to observe them. Furthermore, remember that light is emitted in individual packets called photons. Suppose the object are emitting photons as the object fall past the horizon. At some point, the object will emit it last photon before the object cross the horizon. That photon will reach the observer at some finite time -- typically less than an hour for that million-solar-mass black hole -- and after that the observer will never be able to see the object again. (After all, none of the photons the object emit *after* the object cross the horizon will ever get to the observer.)
As what above explain, the object will turn red and fade away.
Stephen Hawking's new way of perceiving black holes !
- zong
- Administrator
Wow thanks weixing.. you explained what I had tried to explain for so long.. Maybe I really should start brushing up my english skills so that I can explain properly..
This question hinges on the idea of time dilation. It is possible for time to come to a standstill in mathematical terms. This will be when the space-time dimension has been stretched to infinity. This can only (theoretically) happen when very very very near to the black hole itself. A G-field just strong enough to trap light still cannot bring time to a standstill, only slow it down very drastically.
More fun questions! I like'em.ChaosKnight wrote:Alright, riddle me this: within strong gravitational fields, time slows down. Will time come to a standstill if the gravitational field is strong enough to trap light?
- QuantumGravity
Alright, there is no paradox then.
Another question, zong.
Suppose there were two observers, A and B.
A is stationary.
B is accelerating at constant magnitude as observed by A.
B will see A accelerating in the opposite direction, but will the magnitude be a constant also??
i am thinking acclerations observed by both are different, but if one is constant, the other is.
A is stationary.
Anyway, please post any new question on a new topic... OK
Or else, this thread will become "The Never Ending Story"..
Both will observe the same acceleration.Suppose there were two observers, A and B.
A is stationary.
I really don't understand what you mean??? May be you want to explain why both observer cannot observe the same acceleration... since only B is accelerating and A is stationary... my math is not that good lah...
Sorry i take that back. Different observers can see the same acceleration if at that point in time their velocity is the same. But this is generally not the case.
Since both observers agree on their relative velocity, but since they cannot agree on time, they also cannot agree on acceleration. Can somebody confirm this??
