M20 Trifid Nebula
DotDotDotZ
Post by DotDotDotZ »
wow....beautiful photo :shock:
cataclysm
Post by cataclysm »
A modified camera shouldn't affect the blue channel... May be you are too aggressive with your processing??
Could be. I forgot to mention that IDAS light pollution filter was employed. That may be the cause of it. Will try without the filter next time. Too kia su la!
The reason why cataclysm's photo is poor in blue is simple. Because his H-alpha photos (which doesn't have blue and green spectrum) have exposure that is longer that his colour photos. So when you stack them together, you see very poor blue.
This may not be the case. The H-alpha frames were grey scaled and were only used as luminance for the final image. My best guess is the Mewlon is inherently slow and coupled with the higher sensitivity to Red of the modified camera may be the cause. To get the rest of the colours, i would probably have to tripple or quadruple the total exposures.
Anyone has other ideas?
why do you grey scaled the H-alpha? You are not taking RGB are you?
Maybe you should explain exactly what you did, if not it will be hard to deduce why the blue is lacking.
wow weixing...
This seems to be your best effort ever! The image is so rich in colours they are awesome....Hope to see more of this expecially from Singapore skies.
Cataclysm is not doing too bad either...The master and the disciple! heh heh
excellent image weixing! you might like to try www.1111mb.com to host the images, no pop-ups and 5G of space. I am using that for my personal website
Photon Bucket
kelvin,
you might like to take longer RGB data for the modified DSLR. Also when you are in PS, perhaps you could check that the histogram profiles for each colour channel has roughly the same spread, nevertheless it is a good try!
Photon Bucket
In the first place, need to also know what is being "modified" in that 350D. There are three kinds of modification that people usually do
1) Totally remove camera filter. For this, you get all the spectrum but you can't autofocus or use the viewfinder
2) Replace camera filter with clear glass. All the spectrum will be there and you can autofocus and use viewfinder
3) Replace camera filter with a different UV/IR filter or deep sky filter. Now this one is tricky. You need to find out first the properties of this filter before using any other external filters.
So which one of the above is the modified camera? It will have impact on the images.
