Singapore is very humid. If you check the weather forecast, the relative humidity is usually from 70% to 95%.
IMHO, dew shield is basically a must in Singapore for SCT user, unless your observation site is usually windy (dew usually won't form if it's windy) or you don't plan to observe past mid-night. The dew shield will not only delay the dew formation, but also act as a light shield to block stray light... For SCT, it also make the front of the SCT a bit heavier and allow the scope to balance a bit easier.
By the way, a 2x barlow will also be a nice addition as you'll be able to get 3 magnification (2 magnification if your diagonal is screw on type) out of a single eyepiece. For example, a 25mm will basically give you 50x, 100x (with 2x barlow insert on the diagonal) and 150x (with 2x barlow insert before the diagonal).
Happy observing and have a nice day.
Opinions on the Nexstar 5SE as a beginner scope
- codenamejag
Take a look at this SCT website for SCT, it's quite useful:
http://sctscopes.net/index.html
http://sctscopes.net/SCT_Tips/Need_to_H ... ntion.html
Check out the dew prevention section on the above website:is there a difference between a dew heater and a dew shield and dew removers (heater strips)? which should i get to use with the 5" SCT?
You can easily make your own dew shield out of simple cardboards or equivalent (water resistant material is even better). Just coil it around the front part of the scope like a pipe. This will effectively minimise the chance of dew landing on your scope when you observe through the night.
However, if you are observing in Singapore, most of the time it will be used to keep out stray lights instead.
Forget about the dew heaters or removers. You will only need those when you get out of the urban SG areas. I have never had any dew problems when observing in Singapore. Even so , getting heat packs are much more cost effective than dew heaters.
Hmm... strange?? Where do you observe?? Dew is quite serious in Tampines. Dew usually start to form on all my stuff after a few hours of observation especially after mid-night, unless it is windly. Most of the time, my bag, star chart and outside of the tube is wet after my observe session. That's one of the reason why I prefer Newtonian which basically don't have dew problem as the tube itself act as a large dew shield.... hmm... if I remember correctly, only one time the dew is so serious that my secondary mirror and eyepiece dew up...I have never had any dew problems when observing in Singapore.
dew do form out there in the field. just that how much forms on ur scope may vary alot. most nights i have no problem with just the dew shield on my refractors, but for those long sessions in mersing, even with the extra extra long dewshield on the 3" toy scope, it does dew up.
a dewshield is very useful, esp in sg since it helps to block out stray light as well. for an sct it's even more useful due to the corrector plate infront. it keeps out dew and unwanted fingerprints.
- codenamejag
In the case that dew forms on the corrector plate, please do not wipe it off to prevent scratching the optics. Point the tube downwards and let it evaporate slowly.
Photo Album:
By the way, if you keep the scope in the dry cabinet, don't put the cover on. If you do so, fungus might still grow if too long didn't use as the cover will trap the moisture inside.
If you don't have a dry cabinet to keep the scope (like me), you can do the following:
1) Use it often,
2) Air it often,
3) Expose to sunlight regularly.
1) Use it often,
2) Air it often,
