I went to the park at 8pm as i said. Sad that nobody was looking for me for the first hour, though understandable seeing the condition of the sky.
first up i went to vega in lyra. surprise! i can actually see the whole constellation in the finderscope, even with the thick clouds! I didn't expect that. However, my search for the ring neb didn't result in any tangible "fuzzy patch", as expected, but at least i can see the constellation!
Moving about in that area, i see a small cluster of stars in a 1deg(i think) field. Looks like stray stars, but according to my atlas there's a cluster in that area, and the clouds hinder my judgement of whether it is really a cluster, so i shall stop commenting about the "cluster" for now. I think it's CR399, the coathanger cluster.
As time goes and my eyes get used to the skies, i spot cygnus and gamma cygni above it. Estimating the distance of the 2, i "pointed" at albiero - 3x distance between alpha and gamma cygni, extended in the direction of gamma from alpha, then to the left a little. Amazing! I didn't even need the finderscope. It's already in the view of my scope! The split is very cute, and the 2 stars of blue and red hue is very easily seen, even when i look up at the sky and can only slightly "see" the star through the thick clouds.
Looked in the direction of orion - and saw very very very distinctly - a lot of M0 (clouds).. not even rigel and betelgeuse could be seen
Went over to jupiter. The 4 moons are distinct, but the planet itself is very soft and blur, no matter how i focus. At 48x, i could "see" a few bands there. Not sure is it real or my imagination. At 150x it's impossible to focus.
Saw antares, "traced" out the constellation, and pointed at M7. Initially i was shocked to see only so few stars.. i couldn't even confirm if that was M7!! Then i moved the scope a little and found M6, which was also another disappointment.
By around 9pm, i was done with the above and nearly wanted to start packing, but clifford finally came, and i showed him the above things in reverse order, M6 first. Then i left for home around 945pm.
Goes to show something: no matter how bad the sky is, something can still be seen! also, a 5" mct rocks!! Portable, quick set-up, can see so many things even in such lousy skies!
