After 10-11PM, I noticed the clouds were dispersing and I decided to shoot some solar system objects. The idea was to use a very small APO refractor and a small (1in) astro-camera to track their celestial motions in a time frame of 1 hour or 2.
The telescope is 70mmF6+.79x, giving a FL at 330mm. The camera is ASI183MM Pro -- high quantum efficiency but quite a small size (small FOV). The pixel size is ~1.6arcsec/pixel. The challenges include a) getting 1-min subs on SkyGuider Pro with minimal trailing -- using an autoguider. b) manual GOTO to frame the target object in the tiny FOV (I resorted to iterations of RA and DEC adjustments) -- compared to Sky adventurer, the skyguider pro lacks in fine adjustment on both RA and DEC.
I slightly modified the system so that the autoguider sits at the end of the weight-balance bar (rod), which saves some dead weight to ease the load.
ASIAir Pro was the astro-computer. A quick procedure of rough polar alignment + drift alignment brought me a nearly flat DEC drift line. However, I had some trouble with the RA autoguiding. But I am not very sure about the result -- the autoguiding seems problematic.
Anyway, back on my computer, after removing a large portion of slightly trailing shots, I am quite impressed with the capacity of this configuration. With several minutes worth of exposures (from my HDB estate in Punggol), it could detect objects as dim as mag16 or even mag17.x. I guess it was helped by my decision to remove any filter from the optical path -- so the camera sensor receives all the photons --- and those dim objects are probably shining more in the near-infrared spectrum -- in which the light pollution is much weaker while the camera's QE drops but not as much.
Firstly, I liked to capture small but far-away object -- here is a large Jupiter trojan (588) Achilles. Note this picture is in the original pixel scale.
