1. I sold some of my unused astrophotography accessories this week, so I was able to afford some plasterboard to start covering the ceiling. It will be good to seal all that fibreglass insulation in and fit the lights.
2. I have found some foam-rubber on a roll that seals nicely the gap between the dome-support ring, and the dome ring itself. I've glued it to the bottom ring only, so the top ring slides nicely along it without binding or too much resistance around the circumference of the dome. You can see it just above the unlaid carpet in the picutre below. The other issue is to seal the light-leak from where the dome panels meet the weather skirt, as well as cover the sharp edge of the sheet-metal.
3. I cut some of the foam rubber into short strips and glued them all in. It dresses off nicely and makes it safer and light-proof.
4. Just to give it a bit more of a finished look, I've adhered the caution-tape to it. Looks good and clearly distinguishes the edge of the dome.
5. I think I'll leave it at that for caution-tape or else it will take over. The carpet looks worse and worse as the dome and fittings improve, but the great news is that someone has offered me much nicer carpet!
6. The stairwell is coming lose to completion too. A few sharp edges to clean up and a gap to fill and dress, then some trim around the end of each tread and it's done.
