My little window...
kimo
Re: My little window...
Post by kimo »
Yes, still can see nebula. I think need very clear sky. which mount are you using?
Sivakis
Post by Sivakis »
Kimo
I'm using the Celestron CG-4 with RA motor.
Since my scope is the Astrotech AT66ED, with Canon EOS 1000D attached, its less than 3kg with the Mount capacity of 9kg.
Sivakis
Post by Sivakis »
It's amazing what a clear night can produce, even if it's only 20 x 30sec frames (or 10 minutes)
My proudest Eta Carinae so far (although I still seem to get quite a bit of flare off the right, which I had to crop off
Sivakis
Post by Sivakis »
NGC 4755 Jewel Box 29 x 30sec
Sivakis
Post by Sivakis »
Revisiting NGC 5128. Only captured it once about 1 year ago (thanks Gary for identifying it as the Hamburger Galaxy!)
I found it rewarding to compare the differences :D
NGC 5128 Centaurus A 22 x 30 sec
Sivakis
Post by Sivakis »
Finally bought the Orion 5123 1.25" Eyepiece Extension Tube and managed to achieve focus on my Afocal setup!
Cos it's only an AT66ED, didn't expect much, but am happy with this first result!
Hello Saturn :) (289 frames stacked from ISO3200 video on EOS 70D)
Sivakis
Post by Sivakis »
Afocal Moon:
Question: I noticed all those bright dots on the surface that is present on all my static shots as well as in the video. Can't seem to google out what they are. Can someone enlighten me please?
nice crisp moon! hot pixels?
Photon Bucket
superiorstream
Post by superiorstream »
Hi Sivakis
Those white spots and white lines coming from craters are actually impact dust that arise from
the impact of these meteor that give rise to the
crater....the most prominent being the crater tycho.
My two cents.
Sivakis
Post by Sivakis »
Thanks Remus and Chia
Nope, not hot pixels. I wasn't tracking so the moon in my shots were moving across the frame.
Anyway, here's a 100% crop of an unprocessed single shot:
They were also visible through the eyepiece almost like bright lights.
I think Chia is right, tiny craters. This image I googled seem to show that:
http://www.hrastro.com/FullMoon/FullMoon_1680x1680.jpg
Thanks, mystery solved :P
