Hi,All
Thanks to the encouragement of Gary, I am thinking of posting those sunspot,prominences,CME ,filaments photos here as the sun is getting more and more active now. Our cycle 24 peaks during the year 2012,2013. They are totally unedited to preserve its scientific value. Any objections? Because when the sun is active, sunspot shape may change every 10min or so and a CME needs at least 5 photo to illustrate its changes. Filaments dances like snakes on the sun.--otherwise peeople may think I am doing some spaming. If ok,I will start with sunspot 1401,1402. Thanks for the advice.
Unedited Solar Images from Jan 2012 onwards
Re: Posting of unedited solar images-Jan 2012 to ???
i would definitely like to see! but im sure about others
Posting photo on behalf of superiorstream. Enjoy!
Hi,All
Thanks Gary.Sunspot 1410 has changed its profile and a series of small dots are growing around it.I shot it early today;but will post later;instead will post sunspot 1401,1402--the 800,000km x 800,000 km sunspot thats responsible for those aurora,S2 disturbances.Stay tuned.Thanks for watching.
- wucheeyiun
Hi Chia, i help process your image ( hope you don't mind )
This bring out a little more h alpha detail and pronounce the prominence.
Hi,Chee Yuin
No problem,only thing is I dont know how to process.Your processing bring out the bright regions and the snake like filament prominently.Thanks.This sunspot is expanding today,but I will post after finishing 1401/2 which is one of the largest sunspot in this cycle.
All the photos imaged by superiorstream for posting in this thread will be uploaded to the same picasa web folder. Those who are interested to see them as a slideshow can click on the following link. You may use the web options available to play/pause the slideshow and increase/decrease the interval timing. Enjoy!
Solar Astrophotos by superiorstream (Slideshow):
https://picasaweb.google.com/1003095379 ... 7743081362
Re: Unedited Solar Images from Jan 2012 onwards
Hi Superiorstream
Its OK to post the images but I am shifting it to astrophotography which is the relevant catgory. If the photos are about certain events rather than generic photos, you can post it under astronomy events.
Thanks for sharing.
Regards
Thanks for sharing.
Regards
Hi,ALL
Thanks Gary for the wonderful work and Airconvent for the shift to astrophotography.Concerning these 11 sunspot 1401/2 photos,pls note the following
1)The granulation on the sun shows up as an uneven background of choatic uneven 'dots' if you look carefully.
2)The whole sequence--15 to 27 Jan is 12 days;so if you add movement to the very edge of 2 days;it adds to 14 days--consistent with the period of rotation of 28 days of the sun.
3)At its largest,the whole sunspot took 2 frames to cover.Length wise,one frame covers approx 800,000 km.
4)I never edit those images.If you had notice,one dot in the 2nd frame--on 22;25...-- is always blurr;yes it is no matter how I adjust the focus.Such blurr sunspot are rare.Editing will destroy the info.One of the reason I dont edit;but shot many and choose the 'best' in the selection.
5)Notice this active sunspot keep on changing shape.This is true of very active sunspots.
Thanks for watching and upcoming---1401/2 in Ha and Cak.However,due to the frequent haze in the sky,fewer were taken.
