Design of telescope trolley for astrophotography
Re: Design of telescope trolley for astrophotography
Interesting.. where did the pier pipe come from? can these be bought in small-ish quantities?
I'm thinking of making a portable pier..
shirox
Post by shirox »
you may wanna add 4 screw legs that can lock the height and take the weight instead of the wheels. This may damper the vibrations and movements in the event if your mount is alligned to the north.
ChaosKnight
Post by ChaosKnight »
Project closed
Hm. There is a large aluminum shop at Block 803 King George Avenue.
I used to buy aluminum tubing there, but the lengths were inconvenient (20 foot).
What is the minimum length of the 4" diameter tubing?
Also you have that thick aluminum plate on the top. I am not sure that can be purchased in such a small size / quantity..
also the frame... looks like it is aluminum U-channel? or angle bar stock?
these are just bolted together? or some MIG/TIG welding?
Also... 4" tubing might be a little too small for any significant load. I read somewhere that deflection is inversely (exponentially) proportional to the diameter of the tube.
so an 8" tube even made of very thin-wall material, would be substantially more rigid than a 4" (about 16X more rigid I think).
ChaosKnight
Project closed
ChaosKnight
Project closed
Thanks for the additional info.
My payload is.. substantially greater. Up to 15kg of mount, 15kg of counterweight, and 12-15kg of scope, camera, etc. That would be the maximum load.
ChaosKnight
Project closed
ChaosKnight
Project closed
