The only draw back is the frame rate for imaging. While we "blow up" the planet size so much, focal ratio also higher and dimmer image as the result...gain & exposure time needed higher and longer...and thus, frame rate dropped a lot.
Thus, for good result, seeing is almost everything beside optical collimation and quality.
