darkened lens edge
added 3 baffles
internal 1/4" mounting nut to camera tripod
lens cell made from plastic cookie jar, epoxy ,7 layers of crafting foam as spacers
tube body and focuser from 106mm wide body shampoo bottle, focuser tube from 60mm fish oil bottle and 48mm pvc pipe
eyepiece is taken from old binoculars , kellner design, focal length and afov unknown
entire scope can be open for washing when it accumulate fungus
total weight is 550grams, materials expenditure less than $40
crafted with simple tools
clear aperture may be 76mm only due to my rough workmanship
the carbon fibre style vinyl sticker sheet didn't work out as I hope, makes the scope look uninviting and less fun
![Image](http://i.imgur.com/3WrdvxN.jpg)
![Image](http://i.imgur.com/HERVl9x.jpg)
![Image](http://i.imgur.com/kEtfjUo.jpg)
stuff required
$2 daiso A+B epoxy , curing time is stated 10minutes but 1 day is needed for it to turn really hard and brittle
$2 daiso double sided black foam tape 1mm thick 30mm wide 3m long
$3.20 popular A4 size black crafting foam 2mm thick 10 sheet (usage is 5 sheets +1 for short dewshield)
$2.30 popular Staedtler lumocolor black permanent marker
$3 black vinyl sticker sheet 4 square feet (usage 2sq feet , bought online)
big and small scissors, gas stove, iron nail, plyer , plastic cutter, hand saw , plastic bags , toothpick , lego parts, hotglue , scotchtape
*update June 2014*
There is a visible film on the objective lens. Most probably fungus. My estimate was 8 months and this new data of 6 months is close.
Can be washed away with tap water and dishwashing detergent, this method is not recommended for more expensive scopes as it can cause micro-scratches on the coating.
![Image](http://i.imgur.com/3355Dnq.jpg)
internal crafting foam baffle and polyester felt , both bought from popular bookstore
![Image](http://i.imgur.com/yA5ghtB.jpg)
