Hi all,
I have a question. Do Polarizing filters adjust the brightness of images to a better level for observing? Or It is only for photography ?
Best regards,
John
Sent from my GT-I9300 using Tapatalk 2
Polarising filter
- Johndepro
- Favourite scope: Powerseeker 127 EQ / Powerseeker 50 AZ
Polarising filter
-_JOHNOOI_-
- Mariner
Re: Polarising filter
Never used one before but comments from seasoned veterans suggests to save your money.
OCULARHOLIC ANONYMOUS!!!
- Johndepro
I see ... thank you Mariner
Best regards ,
John
Best regards ,
John
-_JOHNOOI_-
- Great Red Spot
- Favourite scope: Newtonian
Hi John, if the moon is too bright, try stopping down the aperture by covering the front with something?
- Johndepro
Oh ok , thanks for the tip Great red spot
-_JOHNOOI_-
Get the 48mm polariser. Thread it into the 2" to 1.25" eyepiece adapter and turn it around for viewing of moon.
- Favourite scope: C8 XLT
Hi John,
The effectiveness of the polarizing filter will depend on what objects you inten to view. For viewing of the moon, using a piece of cloth as mentioned above will do the trick haha. I realize that thankfully as I nearly bought multiple filters out of excitement can though they may not be what I need. The area of cover will depend on how bright or dim you want the object to be.
The viewing of other objects may require more dedicated filters.
Let us know how it goes!
Clear skies to you!
Clear skies to you!
- Johndepro
Hi , joshuapzkpfw
Thank you for the tip.
-_JOHNOOI_-
Polarising filters are typically used to cut glare. Light operates in 2 polarizations. By filtering one away, you can cut the light by half. That's how Polaroids specs work.
And yes, like what has been said, reducing the size of the aperture in anyway will cut the brightness. A piece of opaque circular cardboard with a circular hole in the middle will helps. Just avoid blocking from the centre. That increases central obstruction and reduces contrasts. (For refractors anyway)
Cheers
Cheers
