How to set up EQ mount in Singapore
khoojwn
Post by khoojwn »
Hi all, is there any tutorial that teaches how to set up EQ mount in Singapore? Which star can be used?
I'm new to astronomy and I've been considering between AZ and EQ and setting up an EQ mount seems to be most daunting to me.
Would appreciate some advice please.
Mariner
Re: How to set up EQ mount in Singapore
Post by Mariner »
From what I was taught by some of the old birds here, get a rough alightment first and then do drift alignment.
http://www.backyardastronomy.net/drift_alignment.html
I'm still a noob learning to do drift aligning but it gets me pretty good "Go-to" results on my mount.
OCULARHOLIC ANONYMOUS!!!
ivan
Favourite scope: TAK-oyaki
Post by ivan »
First of all, what is your main interest in astronomy? Is it visual or AP? Also, are you planning to get a motorised mount?
If you are doing visual, a rough alignment using a compass should be more or less sufficient, imo. If your EQ mount is not motorised, there is even less of a need for precise alignment because you will be constantly using the slow-mo cables anyway.
However, if you are planning to do long exposure AP, then do drift alignment, as Mariner mentioned. There is no way to align to polaris because it is only a degree off the horizon.
Just a casual stargazer
khoojwn
Post by khoojwn »
Thanks guys. Right now I'm not into AP yet. Just viewing, but thought it'll keep me open to the option if I own an EQ instead of AZ. Will definitely join in more sessions and watch the pros in action. Haha
