Skywatcher star adventurer
mymoon
Post by mymoon »
Well my new "toy" mount arrived. Being Ramadan no time to play play with it.
Got it from penang vendor ( no relation except for a satisfied customer) the whole lot with all accessories. Will be used on the Gitzo tripod.
For those who like them small.
This you tube describes it very well.
http://youtu.be/sFzQiVwL1NU
Certainly a very portable EQ mount but without a goto.
Cheers
Aziz
kochu
Re: Skywatcher star adventurer
Post by kochu »
Looks kike a great and versatile product. Look forward to your review after trying out.
Brgds
Kochu/20-7-14
I have some photos here:
https://picasaweb.google.com/1036942525 ... Adventurer
I used it in the UK (where Polaris is gloriously high in the sky) and so polar alignment was fairly easy. 2-minute subs at 200mm were not so bad, a better polar alignment would certainly help (and a better tripod than the Benro A350EX I was using).
mymoon, can you share where you purchased it? and did you get the counterweight shaft and weight? I got mine from The Widescreen Centre in London, it was 299 UKP and the CW and shaft haven't shipped yet.
mymoon
Post by mymoon »
I see that you have play-play with the "toy". I was there too around the QE birthday and the naked bicycle ride around London. But the delivery dates are not suitable for me. So I opt to purchase locally.
Here unfortunately we may have to do drift alignment using the Robert Vice DSLR method. But using an autoguider (it does have an autoguider port) maybe a compass and inclinometer method will be sufficient for up to Canon 400mm f/5.6.
I notice too there is a mechanical DEC fine positioner and an electrical RA fine positioner(12X) to help position the stars for the drift alignment.
I got the complete set including counterweights and shaft from here
Cheers
Aziz
1700 MYR = 664 SGD.
So almost exactly what I paid (306 GBP = 645 SGD).
Considering that you already got the counterweight and shaft, you got a better deal, because I now have to pay for onward shipping of the CW and shaft from UK to SG via SingPost/vPost.
I just measured the periodic error, it's about 23" p-p with a 15-minute period. Not bad actually.. typical China mount performance.
mymoon
Post by mymoon »
Question:
I note on other boards some discussion on equatorial mount's periodic error and how it can be reduced. Can it be done with this mount ?
More pertinent is it worthwhile.
Cheers
Somebody in stargazers lounge has taken it apart.
There is no PEC indexer. Hence PEC is not possible.
The solution is to guide probably with a stand alone guider like the lacerta mgen.
Or stick to under 2 minutes at 200mm.
Did some more data capture. It has a 144-tooth worm. Fundamental periodic error is about 28" to 30" p-p.
I DIY'ed a counterweight shaft. No change in performance. Guided performance is about 2" RMS.
http://orlygoingthirty.blogspot.sg/2014 ... le-eq.html
http://orlygoingthirty.blogspot.sg/2014 ... rt-ii.html
