Car Audio Amplifier just disconnected from his vehicle (scraping) and in working condition.
Selling price : $80
RMS Continuous Power output (@ 12.0V 20 Hz to 20 kHz)
25 watts x 4 @ 4 ohms, 0.08% THD
35 watts x 4 @ 2 ohms, 0.3% THD
70 watts bridged into 4 ohms, 0.3% THD
- Dynamic Power (a 14.4V, 20 Hz to 20 kHz)
40 watts x 4 @ 4 ohms, 0.08% THD
50 watts x 4 @ 2 ohms, 0.3% THD
100 watts bridged into 4 ohms, 0.3% THD
Frequency Response - 10 Hz to 50 kHz (+0, -1 dB)
Signal to Noise Ratio - 100dB
Slew Factor - Greater than 5
Inout Sensitivity (for rated power output) - 200mV to 4.0V (1.0V at center detent)
Active Network Frequency and Slope - 50 to 200 Hz, 12 db per Octave
Dimensions: (W x H x D) 240mm X 53mm x250mm ( 9-7/16" x 2-1/16" x 9-14/16")
Weight: 3.0Kg (6lbs)
If interested pls contact or msg Kuan at 92378724
